General Tech Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
92 rs to z28 Rearend swap
Old Oct 27, 2009 | 10:52 PM
ajlawson's Avatar
Default 92 rs to z28 Rearend swap
i want to know if one, the z28 rearend is posi traction, and two, if it would be worth changing out the ends?... i plan on buying a new(er) engine or building mine up.. i just need some input
Old Nov 2, 2009 | 12:14 AM
mighty mike's Avatar
some of them are. it was an option. look on the RPO codes for the code G80(limited slip) and i think it is worth it seenin as how ull have both tires getting power instead of 1.
Old Nov 2, 2009 | 04:02 PM
ajlawson's Avatar
so should it drop right in? thank you by the way
Old Nov 2, 2009 | 05:07 PM
blackz87's Avatar
Well if you are buying the Z28 rear axle I would open it up and check what gear ratio (stamped on OD of dr gear) and check for a Limited slip ( check picture). I would not waste the money if it is a 2:73 like the one in the RS. They are both 10-bolts and will bolt right in. You did not give a lot of info on the Z28 rear axle to really give you a good opinion if it is worth it. Ratio, brakes and etc.
Old Nov 6, 2009 | 12:49 AM
ajlawson's Avatar
i havent had a chance to get to it yet. sorry. but thanks again. what is the better ratio on the z's rear?
Old Nov 6, 2009 | 07:31 AM
blackz87's Avatar
Only ratios available (year unknown) that are improvement are 3:23 & 3:42 (10-bolt)....
Texas70z28
70-81 Transmission & Differential
Sep 19, 2013 10:52 AM
cnance
Aug 7, 2011 11:44 PM
thetal1
May 30, 2011 11:38 PM
rally72
70-81 V8 Tech
Jun 4, 2009 11:31 AM
3RDGENZ28TX
Mar 22, 2007 01:09 AM
