Waterpump shaft play
So, changed the WP, only to find the seal leaking.
Removed the WP shaft seal and checked the play and found this:
Does this look like too much play in the shaft? And if so, what's my next move here...
Thanks,
__________________
1995 Z28 Convertible. Stock LT1/Auto.
Thanks,
__________________
That's about how mine was, and yours appears to be normal. Seeing how the shaft is connected inside, I don't see how it's possible for it not to move. And once connected to the pump drive shaft, with the new tight fitting o-rings, it will be stabilized. With that said, your leak could have something to do with how the seal was installed. There's a right way, and a wrong way (which will make it leak).
Here's the right way, and others have used different types of install "tools": https://camaroforums.com/forum/lt1-l...ve-seal-43601/
Tighter than a....
Well, lets just say it was VERY tight after I put the new seal in.
All put back together tonight and seems good so far. I took it out for a 20 minute rip and it doesn't seem to be puking anything onto the shop floor.
I'll check again in the morning to be sure nothing dripped overnight.
I ended up using the cap from a tire crayon to put the new seal on...worked like a charm.
