LT1/LT4 Tech 1993-1997
Solid lifters question
Old 06-03-2011, 02:37 AM
x01660's Avatar
The Mustang Hunter
Default Solid lifters question
Would it be possible to build an LT1 with solid lifters?
The goal would be to build a high revving (say 7200 RPM redline) LT1 that still produces the loads of low end torque that LT1's are famous for.
Or is that wishful thinking? I am not to experienced with the specifics of engine internals. I mean, I know how everything works, but not the details like cam size, etc...
Thanks for the info.
x01660
Old 06-03-2011, 09:46 AM
yes solids will work in a lt1. lt1 thats set up to rev that high is not going to produce loads of low end torque. at least not compared to high end.
Old 06-03-2011, 11:23 AM
Y2K's Avatar
Y2K
Y2K is offline
You're probably better off with something like these short travel hydraulic rollers.
COMP Cams 15853-16 SMALL Block Chevy Short Travel High RPM Race Hydraulic Roller Lifters - Lifters - Atlantic Speed Warehouse
Solids are a PITA,always needing adjustment and prone to destroying pushrods and rockers if you over-rev missing a gear or something.
I ran solids in a 427 in a '69 but they were easy to get at.
Not the best for a daily driver though unless you like pulling the valve covers a couple times a month or more lol.
libertyforall1776
10-08-2007 12:05 PM
ScottD
05-17-2007 10:41 PM
GRIFF
10-16-2006 06:49 PM
GRIFF
10-09-2006 01:24 AM
American_psyco
09-06-2006 07:01 PM
Quick Reply: Solid lifters question
