LT1/LT4 Tech 1993-1997
hesitaion at startup
Old 12-29-2006, 01:15 PM
illumastar's Avatar
Default hesitaion at startup
my z28 at startup goes to 500 rpms then stays there for a few seconds then after that it goes upto 2000 then drops back dwon to 1000 and holds stedy the same thing happens when i goto put the car into gear could this be the optispark? I allredy have the newer msd one installed can i clean this or do i have to buy a new one if this is the case
Old 12-29-2006, 06:15 PM
Default RE: hesitaion at startup
Check engine lite lit? Check for vacuum leaks, clean out or replace IAC valve. Check EGR valve.
TheArtfulLodger
04-07-2012 02:56 PM
CoyotesLaugh
11-29-2010 06:09 AM
JordanN
09-09-2010 05:08 PM
BadVRod
09-10-2009 11:23 PM
hotrodguy1986
01-26-2007 01:28 PM
Quick Reply: hesitaion at startup
