Question about power
Old Mar 20, 2007 | 09:58 PM
Eric89RS's Avatar
Default Question about power
I have a 350 I just got done building and finally got it put in my 1989 camaro. My question is how much power do you think it will put down on the dyno? Its a 350 bored out 40 over with stock rods and crank. The pistons are domed 9-6-1 compression. It have a 510 lift cam with hyd. roller rockers with dart cast heads. I have a victor Jr. intake with a holley 770 carb. I also have hooker super comp headers into a true daul 3 in exhaust. Any one have any idea what kind of power. I was thinking a little over 400 at the crank what do you think.
Old Mar 20, 2007 | 10:14 PM
74454bb's Avatar
May 2007 ROTM
Default RE: Question about power
Why the Victor jr intake? I thought that was a good circle track intake. And 350 to a tit over 400 may soundclose. Have you driven it yet, and if so what dous it feel like?
Old Mar 20, 2007 | 10:44 PM
Eric89RS's Avatar
I choose the intake bc it makes pretty good power almost up too 7000 rpm's. Ya I've had it out and runs really good. I have a turbo 400 in it and 411 rear gears. Now i just have to get a good set of tires but its pretty fast.
Old Mar 20, 2007 | 10:49 PM
74454bb's Avatar
May 2007 ROTM
Do you have any pic's up yet? and what size tires are you going to use?
Old Mar 20, 2007 | 10:55 PM
Eric89RS's Avatar
No I dont have any pics yet its been done for a while but I took any pic bc i have it all primmered up too. I have a 275 75 15 on the back.
Old Mar 20, 2007 | 10:59 PM
74454bb's Avatar
May 2007 ROTM
We still like them in primer to. that should be wide enough in the back to handle the power. And did you mean 275/ 60/ 15's ?
Old Mar 24, 2007 | 12:00 AM
machineman's Avatar
I'd almost bet that you would make better power in the RPM range that your car probably spends 95% of it's life in with a high rise dual plane intake manifold. Just a suggestion.
Jack_M
Sep 15, 2015 11:24 AM
ACEDEAN
Sep 6, 2010 03:46 PM
BoricuaHec01
Aug 5, 2010 04:20 PM
IROCNeeveeZ28
82-92 V8 Tech
14
Aug 13, 2009 11:16 AM
TearsInTheRain
Jun 23, 2007 12:21 AM
