Burn out help!
Old 06-24-2006, 01:41 PM
JaySan's Avatar
Default Burn out help!
ok so i have a camaro 3.8 liter and how can i do a bad @$$ burn out? I can do one but my tires dont smoke that bad . So should if i get more horse power will i be able to do better burn outs ?
Old 06-24-2006, 04:45 PM
94Z28SHAKER's Avatar
Default RE: Burn out help!
lol, of course more horse power you can do better burn outs, but you can do them with your V6 as well, press down the brake and hold it there, now push the gas petal down about 75% and gradually as it starts spining either let off to about 50% throttle or just keep it gunned, if you dont care about your tires. be patient the v6's dont have much torque so itll take a little bit for a lot of smoke to start coming out.
BTW dont do this often its not good for your car if you want to keep it for a long time.
Old 06-24-2006, 05:19 PM
JaySan's Avatar
so i can really get my tires smoking if i am patient and give it gas ?
Old 06-24-2006, 07:31 PM
Why ??
Old 06-24-2006, 07:51 PM
JaySan's Avatar
what are negative effects or burnin out other than puttin wear and tear on my rotors and brake pads and taking away the tread off my tires?
Old 06-25-2006, 11:37 AM
thirdgencamaro's Avatar
it is bad on the bottom end ot the motor and your trans as well
Old 07-04-2006, 02:54 PM
JaySan's Avatar
when u say bottom end what exactly do u mean? Do u mean wear and tear ?
Old 07-08-2006, 03:24 PM
i have spun a main berring befor on my 2.8 burning out
Old 07-08-2006, 09:04 PM
JaySan's Avatar
I no this might sound dumb but does a 2000 camaro have bearings ? and Where and what does the main bearing do ?
Old 07-09-2006, 08:02 PM
02blackonblack's Avatar
I have a 3.8 and as a matter of fact, I just drifted across an intersection about 30 minutes ago. (just bought the car and haven't seen what it can do yet, at least until today). Of course the more horses it will be way easier, but if you can't get a decent burn out by just stomping on it something has to be wrong with your car. Yeah, "brake stands" (holding the brake and flooring it) are the easiest way but personally, I stay away from that.
Niteblaster
01-22-2012 09:04 AM
stolarczyk189
09-22-2010 04:34 PM
2002SLP
06-30-2008 12:20 AM
JaySan
09-02-2006 06:01 AM
Quick Reply: Burn out help!
