2000 3.8 liter coughing
Old 09-23-2016, 08:59 PM
turcotjs@gmail.com's Avatar
Originally Posted by Volcente
I had a similar problem on another car.
My advice, if you try clean the MAF and the trottle body with the same specific cleaner.
It can only do good to both.
Thanks. The code came back today. I think something that the computer is seeing is also throwing the calibration off, but I have no way to check it. Could be dirt, but I cleaned everything there last year, including the sensor. I'm pretty sure it only happens in closed-loop. I decided to order a new sensor. Will let you all know next week if that solves it.
Old 09-28-2016, 07:41 PM
Originally Posted by turcotjs@gmail.com
Another update. I drove the car about 20 miles yesterday while watching the MAF output on a scanner. The data looked perfect, even when the engine coughed (several times). Then, I stopped the car but let it idle while I giggled the MAF wiring and connector. Also rapped on the top of the sensor, but not even the slightest blip in the output. It may still be bad, but is working pretty good from what I can see. I think this is one of those problems that has to get worse before it can be diagnosed. :-(
Thanks for the help so far and any future ideas.
Jeff
Guys, the new MAF arrived today, and I quickly ohmed the terminals. Sure enough, one of the readings was way different from the old one. I installed it, cleared the code, and took it for a spin. No coughing and no MIL. Thank God and that you guys too!
Jeff
Old 09-29-2016, 08:38 AM
Volcente's Avatar
Great!
daniel96
11-30-2006 11:28 PM
daniel96
11-28-2006 09:47 PM
2fast4u
09-21-2006 01:26 AM
chevy camaro
07-28-2006 01:17 AM
97FIRECHICKEN
VS
12
06-23-2006 03:40 PM
Quick Reply: 2000 3.8 liter coughing
