Manual to auto swap
Manual to auto swap
Picked up a 96 Z28 6 speed manual really cheap. The only reason i bought the car was for the 6 speed which I plan on putting in my 67. I was going to part out the rest of the car however it turns out the car is too nice to scrap. So now I'm thinking saving the car and putting in a automatic since it would cheaper then trying to find another T56. Any advice on what trans to put in it? What will fit fit without too much trouble and modification?
Any advice would be greatly appreciated.
an auto from a 96 or 97 z28 camaro. trans is car specific. a 94-95 can be built to work in a 96. you will also need wiring harness and pcm from a 96 z28 auto along with the center console shifter and associated linkage, cables and whatever im forgetting. its not an easy switch but can be done if you have another camaro... lol,
700r4 will work, it will still be a bit of a project, You would probably make more money parting the car out then the finish car would be worth. The cut up modified Z will not be worth much
700R4 = 4L60, same animal, different name. The automatic that a 96 would have is a 4L60E, electronic shift. It would be a lot less hassle to install a 700R4/4L60, the only electrical control is the torque converter lockup, which can be made to operate normally using an aftermarket control unit...or you can wire the t.c. with an on-off switch. You'll have to figure if it's worth your time and money to do vs what you could sell it for either as a running car or parting it out.
