From True Duals to a Single Flowmaster
So I made an exhaust change. Here's the set-up before: LPP headers, custom 3 inch H pipe, 2 x 18 inch dynomax bullets with turndowns
Inside the car with the windows up
Outside the car
Walk around
New setup: Same headers, 3 inch into a flowmaster merge, then 1 single 4 inch going into a single chamber delta force Flowmaster with a single turndown.
Pics first:
Started with this
The workhorse for the job
Starting to mock up
I originally was gonna have the exhaust dump out towards the back of the rear tire like this but it didn't work out that way in the end.
This is what I had to do to the rear floorboard
Muffler was almost dragging the ground so I realized more work was needed
Here is the muffler in a better position, and now a new floor needs to be made and sealed up.
Here is the mock up panels tacked in place.
Finished product
Here's what it sounds like
Idle walkaround
Part throttle, keep in mind I have a 4000 converter
WOT from second and going into 3rd
Thoughts and opinions are always welcome
Outside the car
Walk around
Pics first:
Started with this
Starting to mock up
Finished product
Idle walkaround
bens99camaro
02-26-2008 08:41 PM
