transmission fluid? help
I have 2000 ss 6 speed, and i recently changed the tranny fluid, and this is my first time doing it since i bought the car...so i went to auto zone to ask for dexron III and they gave me the Coastal multi purpose DexMerc automatic transmission fluid... said it was the same as dexron III, that they just changed the tag on it. So thats what I put in and now im hearing really bad noises from my trany i think its grinding. Is this the wrong fluid? and could this be f*ckin up my trany?
But, the Dex Merc is a multipurpose fluid that can be used in GM vehicles. You may be cornfusing it with type F, as in Friggin Ford!
ATF Application Guide
It is possible that the previous owner was having the same grinding problem, and put in something thicker. Was the old stuff that came out red tranny fluid, or was it conventional oil?
On a side note, you know those super-duper "trick shift" transmission fluids that make your trans grab and shift better? What a coinkidinky that their properties are very similar to type F.
Back in the "olden days", when transmissions used gear oil (or motor oil), I've used a thicker viscosity to get rid of noises and gear crunching, or to stop the gears from free-wheeling and grinding while shifting from neutral.
I've owned the camaro for about two or more years now and always ran pefect no problems...but thanks alot i apreciate it I'll have that **** changed out asap.. what do u guys recomond?
