Rpm problems
Rpm problems
My 1995 3.4 Camaro is having some rpm problems. As soon as I start it up the rpm will go up by itself until it almost hits 3000rpm by itself and when I step on the gas it starts to choke and it turns off. Any ideas?
That's because it would create a vacuum leak. Vacuum leak would explain your symptoms. Carefully spray some carb cleaner around the intake and vacuum lines to see if there is a change in rpms. If it does that's your problem.
