Power Window Problem
Old 07-01-2009, 04:34 PM
Tar Heel's Avatar
Default Power Window Problem
The other day I rolled my driver side window down and it went almost all the way down then stopped and sounded like the motor was bound up. I rolled it up some then back down and samething happened. I rolled it all the way up and then when i rolled it down it moved about an inch then stopped and made noise. Rolled it back up and now it won't move at all but still has the same sound. Any idea what it could be?
Old 07-01-2009, 07:38 PM
osduck5's Avatar
Best thing to do is take the door panel off and see if you can determine what is actually making the noise. Could be the drive gears on the motor, the window rail, the motor itself or something caught in the track.
Old 07-13-2009, 05:13 PM
is it a clicking sound? my drivers side window doesn't roll down at all but when i try to i hear a clicking sound from underneath the steering wheel. anyone know what this means?
Old 07-13-2009, 05:52 PM
^^^most likely the motor. theres a relay under the dash for the window motors. probly just doing its thing. to the op the duck is right on.
Old 07-14-2009, 02:53 PM
thanks, i figured that but i also thought the window was off the motor somehow, it makes a kind-of raddling noise..
Old 08-21-2009, 03:55 PM
Tar Heel's Avatar
Took panel off and didn't see anything so I guess its the motor. Just went ahead and got another one.
sidewayz28
12-11-2008 02:47 PM
ForgetfulRegrets
01-15-2007 11:30 PM
Rise65
11-06-2006 11:09 PM
Shifty
02-19-2006 04:20 PM
Quick Reply: Power Window Problem
