Need transmission advice or help?
I have a 94 with a 5 speed and the clutch and transmission is out. Good car though. I also have a 94 with an automatic but car has been totaled. Both cars have 3.4. I have seen a lot of places where they put a manual in an automatic car but not what I need.
you will need the the main computer, engine wiring harness, not sure about the under dash and console but i think its got to be changed as well. there is a lockout for neutral and park that i don't think are there in a 5 speed. don't know it the 94 has a bcm or a trans control box. one of those will need to be there.
The last thing you want is a automatic can that can start in gear. That is very unsafe for you and anyone that may be around.
You also need the section of floor welded that has all the shifter mounting stuff.
Thanks for the advice, I am thinking about that complete harness replace and that would be way to much work for me. I have 3 1994 camaros 2 are 5 speed and one is the totaled automatic, my wife can't really drive a manual so good so that was main reason for the swap.
Nebraskaborn
11-14-2012 10:12 AM
sobelizard7@sbcglobal.net
LS Series Tech
05-19-2011 06:38 PM
