'97 Camaro V6 Won't Crank
Old 01-22-2015, 03:40 PM
outonthetiles's Avatar
Default '97 Camaro V6 Won't Crank
I just bought a 97 Camaro 3.8 auto that won't start. So far I bypassed vats, tested the starter, tested the nss, and checked the fuses. Everything checks out good. I turn the key, the dash lights come on and the fuel pump primes. I try to start the car and I hear a click under the dash and the headlights go out but the starter does nothing. Any ideas?
Old 01-22-2015, 03:51 PM
djsquare1's Avatar
A click similar to the click you get when you have a dead or almost dead battery? Throw some jumpers on it and give it a try...
Old 01-22-2015, 04:10 PM
The battery is almost new and tests fine. If I hotwire the starter it cranks over great.
Old 01-22-2015, 04:38 PM
bad ignition switch? or ignition switch arm is out of adjustment. turn the key on and jump starter and see if it runs. if so i would suspect the ignition switch or its in the column.
Old 01-22-2015, 04:40 PM
Old 01-24-2015, 09:57 AM
I already tried jumping the starter, that's how I know the starter is good. It turns over great but won't start.
I don't think the switch is out of adjustment as the headlights turn off and it clicks when I try to start it.
I'm really stumped here. Does anyone have any pinouts of the ignition switch connector so I can rule that out?
Old 01-24-2015, 02:18 PM
factory service/shop manual. go here and click/download the fbody 96. http://www.mediafire.com/?40mfgeoe4ctti
shbox is a good info source. 4th Gen LT1 F-Body Tech Aids
Old 01-24-2015, 05:43 PM
There is a start relay between the VATS module and the starter solenoid, if relay does not work properly the starter solenoid does not get energized.
Old 01-25-2015, 10:12 AM
I pulled the connector off the ignition switch and hotwired it there and got it to start and run. Ordered a new ignition switch for $30 and I think that will solve the problem.
Thanks for the help everyone!
AugustAwaits
12-20-2011 10:23 AM
justinw23453
04-07-2010 01:08 PM
cowboymatt17
03-07-2009 08:13 PM
maguilar496
11-10-2007 11:54 AM
jdwk
09-06-2006 07:23 PM
Quick Reply: '97 Camaro V6 Won't Crank
