won't start after driving for 15-20 min.
Old 03-25-2015, 08:19 AM
torque_is_good's Avatar
Originally Posted by karlscala
The starter i have changed. Put a new 1 in and had same problem so put the old back. I'm thinking. I might have had a bad new starter. And yes it cranks right up when popping. The clutch
you've discovered the culprit
this is not a whack at you but illustrates how using correct terms and full and complete information can expedite solutions
yes, it could be the starter or the cable from the battery
cranking but not starting is more descriptive as opposed to "nothing happens" unless of course "nothing happens" included "it does not crank at all"
no starter engagement, no clicking
If I had to guess, the starter turned slower when it was hot, is that correct? Adding the 2nd battery gave it the extra jolt and away you went
good ole fahion basic stuff like push starting revealed that you had fuel/spark/air
Old 03-25-2015, 08:35 AM
might try a heat shield on the starter.
Old 03-25-2015, 10:49 AM
karlscala's Avatar
It doesn't make a sound no click won't turn over or anything
Old 03-25-2015, 07:44 PM
have you cleaned the battery cable ends. sometimes they can get a layer of carbon on them that won't let the power through. scrape with a knife or if side cable wire brush the heck outa it. sounds like your going to have to start searching with a volt meter and see if you can find where the power stops. good place to start would be the ignition wire on the solenoid, make sure your getting 12 volts when the key is turned to the start position.
Chaotic94
12-23-2014 12:30 PM
DrewDowne
12-07-2011 04:50 PM
Jackrat454
09-02-2009 03:17 PM
Quick Reply: won't start after driving for 15-20 min.
