83 thermostat questions
Old 09-23-2016, 08:44 PM
Dipps's Avatar
Default 83 thermostat questions
Hi, I recently got a 1983 camaro, and this is my first car so I bought it with the knowledge that some wasn't working. The thermostat or if there's a more common name the thing that triggers the fan to come on. right now it has a manual switch to turn the electric fan on. I should also say that the car doesn't have the original engine or trans in it, it has a 350 in it. The wiring in this car is bad and when you look under the hood you quickly find wires not hooked up. I've spend a good amount of time under the hood looking at the wiring and where it all goes, and the cable leading out of the thermostat runs to a relay. Right now I need to get a new gasket for the area around the thermostat because coolant is coming out of it, its not enough to make me not want to drive it. I don't drive that much just I'd rather not burn the fan out. Sorry if I sound really new to this because as stated previously this is my first car. If anyone knows or just wants to ask questions, go ahead and ask. I might be jumping the gun on posting this because the carburetor needs some timing adjustment, and I haven't used a multi-meter to check if the wire coming from the thermostat has any power, and when I searched up the relay the store said it was obsolete so who knows what the problem is. Thanks
camaroman18
06-11-2010 04:25 PM
Saint_Ali
07-14-2006 02:39 PM
camarooner
05-10-2006 04:26 AM
6v49der
04-26-2006 10:24 PM
johnjr
02-13-2006 11:46 PM
Quick Reply: 83 thermostat questions
