Headlight problems, one ok the other very dim.
Old 08-29-2009, 10:26 PM
Franksflying1's Avatar
Exclamation Headlight problems, one ok the other very dim.
I just purchased a 1970 Camaro and am in the process of restoring it. The issue I have now is that when I turn my headlights on the right headlight is bright and the left is very dim (including left side marker) I tried replacing the headlights to no avail. I should also mention that my brights dont work at all.
Any advise. I am not an electrical techie so please keep it at eight grade leve
Thanks,
Frank
PS any advise on where to get a easy to understand electrical wiring schematic. This car has several electrical gremlins.
Old 08-29-2009, 10:54 PM
Check your wiring harness for the front lights. It's possible you just have a bad connection at a junction plug, or a bad ground wire connection. Find any ground wires that are screwed to the front radiator core support or inner fender, then remove and clean them.
Old 08-30-2009, 03:08 PM
Default It worked!
Thanks alot it worked! Any help in getting my turning lights to work?
Jonesz0003
03-15-2012 08:57 PM
hotrodz28454
03-23-2010 03:13 AM
egoods
07-30-2009 08:13 AM
camaro97x1
04-20-2008 11:13 AM
81CanuckZ
09-10-2006 11:04 PM
Quick Reply: Headlight problems, one ok the other very dim.
