79 camaro factory idiot gauges
Old 10-11-2016, 08:34 PM
prost632's Avatar
Default 79 camaro factory idiot gauges
just bought a new project for my daughter,orig a 6 cylinder car,has a nice 350 and turbo 350 in it now,trying to get the idiot lights to work,having problem with the tan wire for oil switch,keeps burning the switch up,found out it has 12 volts on it and killin them,yea I could put some new gauges in it,but like to get these to work right know..any suggestings...
Old 10-12-2016, 12:03 AM
According to the wiring schematic, the 6 cyl model (yours) oil pressure switch had 2 wires, an orange and a dark blue, not a tan. 8 cyl cars had only a dark blue wire. There are tan wires that connect to the headlights, and the idle stop solenoid at the carb, and the brake low pressure switch on the junction block. The oil pressure switch creates a variable ground path, so I get why it burns out with power going to it, just surprised you're not popping a fuse too. Is your under hood wiring a jumbled mass of spaghetti? You have some crossed/misplaced wires.
Old 10-13-2016, 08:26 AM
Everett#2390's Avatar
The pressure switch is just this - a switch - on/off at about 7 PSIG.
A gauge uses a variable resistor - more pressure, lower resistance = lower gauge reading.
Idle solenoid 'tan' wire could be switched.
Dro94Z28
03-10-2013 09:01 AM
Shalamara
01-01-2012 11:47 PM
drJ22
07-17-2007 09:48 AM
patman
06-21-2007 07:17 PM
Quick Reply: 79 camaro factory idiot gauges
