Engine surge
Old 11-03-2015, 10:52 PM
mattnday's Avatar
Default Engine surge
Noticing an idle surge when dropping rpm sown once it get close to zero
A tap on the accelerator and it stops.
Any idea what might be causing this?
Old 11-04-2015, 02:03 PM
running out of gas,,, lol. need more info. what engine, is it carb'd. if so what carb do you have. choke could be sticking.
Old 11-04-2015, 07:32 PM
mattnday's Avatar
Whats funny is I did run out of gas and after that is wen I started noticing it.
350, Edelbrock 4bbl
Old 11-04-2015, 11:52 PM
What is "it"?
If you're saying the rpm's are dropping to almost zero, I can understand why the engine surges, the idle is set too low.
But if the "it" you're referring to is zero degrees outside (assuming you're in the antarctic), then your choke may not be set right.
Old 11-05-2015, 07:12 AM
have a look at whats in the fuel filter. may have sucked something like water or gunk up when it ran out.
Old 11-05-2015, 08:18 AM
Water or sediment would be at the bottom of the tank, whether it's empty or full.
I have however had the "floating orange slime" on an old Vette I bought that had been sitting for years, so picking something up when the tank is almost empty could be a possibility if that was the case. So yeah, I'd check the filter too, especially if my scenarios above aren't what's going on. My current 69 Vette that's been sitting for 20 years (slooooow resto process, lol) surprisingly doesn't have anything, floating or sunk in the gas tank.
VALHAR
11-15-2014 09:18 PM
94z28chevy
06-19-2014 10:04 PM
Z28maro
11-30-2008 12:02 AM
BaByHuEy_05
05-17-2008 04:55 PM
jrb78
82-92 V8 Tech
11
12-16-2007 07:05 PM
Quick Reply: Engine surge
