Transmission Component Weights
Old 10-16-2014, 11:18 PM
tonker1's Avatar
Default Transmission Component Weights
Hi, I'm a second year mechanical engineering student in Australia, writing a technical report on aftermarket vs original replacement transmissions, in particular the TREMEC TKO 500/600 vs Muncie M20/M21/M22!
For part of a materials and embodied energy analysis I need to know the weights of various components of these transmissions. If anyone on the forum has an already disassembled Muncie and could weigh the components listed below it would be much appreciated.
Case
Shafts
Gears
Syncro rings
Bearings
Shifter
Shifter forks
Gaskets
The only Muncie I have access to is bolted into my brother’s daily driver ’67 Camaro and I can’t see him being impressed if I were to take it apart for a report!!!
BZpbp
12-14-2011 08:09 AM
The Emperor
82-92 V6 Tech
05-21-2011 09:52 PM
Sicksty7CamConv
09-15-2010 03:16 PM
microkid
12-15-2009 07:30 PM
98Z28ImportSlayer
LS Series Tech
03-08-2008 10:47 PM
Quick Reply: Transmission Component Weights
