Question on lowering leafs/mono/multi
Old 10-30-2014, 05:18 PM
CaCruiser's Avatar
Default Question on lowering leafs/mono/multi
My car appears lowered. Some parts of the car seem about 4 inches off the ground. The drivers side rear leans 1 inch and I'm thinking about getting rid of the mono leaf setup and going to multileaf. new poly bushings, ubolts, etc. bascally want to cure a few problems, upgrade the suspension, new shocks and the rear end would be all set for years to come.
I want the rear to sit about how it is now or maybe 1/2inch-1inch higher.
Right now the rear fender lip is 26" off the ground with 25" tires.
I'm kind of stumped on which leaf setup to get. I am leaning towards a multileaf with a 2 inch drop thinking my current setup is about a 2 inch drop.
maybe its stock though...I really have no idea! It is possible it is stock with small tires which makes it sit low.
I also have a 12 bolt rear end which I assume was added later.
The rear end also has a couple spacers (roughly 1.75" ) above the leaf and someone here said if I remove those my car would raise that amount.
So I'm looking for some advice. I'd hate to get lowering springs only to find out my rear end is sitting on the ground. Or get stock height springs and its jacked way up.
thanks in advance.
Attached Thumbnails Question on lowering leafs/mono/multi-camaro2.jpg
IndianScout
08-15-2013 09:26 AM
matacaleb20
03-25-2012 09:51 AM
nasty50
67-69 V8 Tech
10-20-2011 06:18 PM
RyanBumZ28
01-20-2007 03:48 AM
todd991
04-23-2006 03:13 PM
Quick Reply: Question on lowering leafs/mono/multi
