LT1/LT4 Tech 1993-1997
Spline joint transmission to shaft question
Old Jun 1, 2026 | 03:56 AM
Alex454's Avatar
Default Spline joint transmission to shaft question
Car on the lift, suspension bottomed-out, but seems like the spline joint is out waay too much (pic below), especially there are sighns of the "other position" previously, as if it was entering the transmission more, based on the marks on the splined pipe (freshly polished, polished previuosly, untouched just before U-joint). Is it ok as is, or does it stick too much from tranny?
Possible reason for the difference is: the LT1 car was initially '94, but got a '97 body from a 3,8 car. I'm not sure if transmission and driveshaft are from '94 or '97 car. Where could be the difference coming from? Are the driveshafts same for '94 5,7 and '97 3,8? It vibrates a bit on high speeds, nothing noticeable up to ~80 mph.
Thanks for your ideas!
Old Jun 1, 2026 | 08:44 AM
looks ok to me, v6 transmission will not fit on a lt1. you may have v6 differential which is not normally a posi trac and usually has 223 gears. do you have stock style trans mount or is it aftermarket poly?
Old Jun 1, 2026 | 12:31 PM
Alex454's Avatar
LSD is in place. And I'm rather at 27X final gear, as per rpm at 75.
Thank you for the opinion. Very pleasing to know, v6 tranny is not in the game
ESPECIALLY, if it looks ok. Cause I, and not only me, have suspected it exits the transmission uselessly excessive far.
What is the chance, previous owner used the driveshaft from v6? Is it different? Compatible at all?
Thanks!
Old Jun 1, 2026 | 01:35 PM
is it two piece drivwshaft? far as I know they is all the same length
Salteen_maro
Sep 11, 2023 12:47 PM
tdspurrier
93-02 Transmission & Differential
Jan 29, 2013 01:38 PM
us63bravo
Jul 13, 2010 09:43 PM
r6rider
Nov 13, 2009 07:13 PM
929BEATSTI
Aug 14, 2008 01:01 AM
