General Tech Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Shop Manual for '22 gen 6
Old Aug 4, 2022 | 04:04 PM
Nardulli's Avatar
Default Shop Manual for '22 gen 6
Hi All,
I just purchased my new Camaro - 2022, 2SS, convertible. Anyone have a source for the factory workshop manual?
Old Aug 5, 2022 | 05:32 AM
Everett#2390's Avatar
Check Owner's Manual for ordering service manuals. Generally last page?
Old Aug 5, 2022 | 09:04 AM
Nardulli's Avatar
That's the first thing I did. Only options there are to buy a second copy of the owner's manual. GM is a lot more aggressive now about trying to drive people to the dealer. Manual tells you to change the differential fluid before taking it to the track. Directs you to a page in the manual that specifies part numbers , fluids and capacities. Under differential it indicates "see dealer". It also specifies adding extra trans fluid before track use but then says the dealer has to do it as it is complicated. Wtf.
Old Aug 6, 2022 | 05:49 AM
Good points. You might try GM Parts Direct,com
Become friendly with a GM dealership manager,
Helm usually publishes their manuals.
Old May 10, 2026 | 09:52 PM
smithbrown's Avatar
Originally Posted by Nardulli
That's the first thing I did. Only options there are to buy a second copy of the owner's manual. GM is a lot more aggressive now about trying to drive people to the dealer. Has anyone tried using Jaguar Land Rover JLR IDS SDD Download or similar third party tools to get around this? Manual tells you to change the differential fluid before taking it to the track. Directs you to a page in the manual that specifies part numbers, fluids and capacities. Under differential it indicates "see dealer". It also specifies adding extra trans fluid before track use but then says the dealer has to do it as it is complicated. Wtf.
Check GM Service Information for the official factory workshop manual for your 2022 Camaro by subscription. If you prefer a printed copy, Helms Inc sells genuine GM factory manuals as well. Congrats on the new 2SS convertible!
The Whip
May 14, 2020 03:00 PM
Marc Pierce
Oct 2, 2015 08:56 PM
sprtplt
May 12, 2011 01:57 PM
Thoreau
Jan 12, 2009 11:49 PM
bluovlh8er
Jun 8, 2007 10:15 AM
