manuals
Old Jun 5, 2007 | 07:36 PM
bluovlh8er's Avatar
Default manuals
hey do them haynes manuals for 93-02, if it says all models does it include the 6 bangers?
Old Jun 5, 2007 | 07:44 PM
usa63t's Avatar
Default RE: manuals
yes
Old Jun 5, 2007 | 08:26 PM
Default RE: manuals
If you have the bux, the best manual is the GM Factory Service Manual, from Helm Inc.
www.helminc.com
Old Jun 5, 2007 | 09:36 PM
bluovlh8er's Avatar
Default RE: manuals
good replies thanks. i bought the chiltons and haynes for the 4th gen for 25/both on ebay.
Old Jun 5, 2007 | 11:12 PM
MadMikeZ28's Avatar
Default RE: manuals
Were they new? Don't be surprised if when you look in the haynes and it looks the same as the chiltons. I got a new chiltons for a later S10 and it looked excatly like a haynes. I looked inside the front cover and it said "published by haynes north America" It even said on the cover "includes wiring diagrams". It does not. It does have typical diagrams that are worthless.
Old Jun 6, 2007 | 03:56 PM
bluovlh8er's Avatar
Default RE: manuals
madmike, your never positive lol. they were only 25 bucks. if it says an easier way to change the plugs i will be happy.
Old Jun 6, 2007 | 07:02 PM
usa63t's Avatar
Default RE: manuals
sorry but it won't do that best advise for that problem is find a friend with small hands ar sombody with a kid who likes cars
Old Jun 7, 2007 | 06:44 AM
bluovlh8er's Avatar
Default RE: manuals
lol
Old Jun 7, 2007 | 08:22 PM
t9ojetpilot's Avatar
Default RE: manuals
[X(] as usual z28 pete renders the best advice, i would strongly recommend the factory manuals that can also be found on ebay for much much less than buying at the dealer. i personally have found much bad information and vagueness in these cheap manuals that try to cover too broad a spectrum. compare factory manual sizes with the chiltons and haynes and youll see the factory ones can be 3-5 times the size for the same vehicle. why?? they contain everything for that exact vehicle. i wouldnt count on either of them telling you exactly how to change spark plugs as they assume the person reading them has some skills but at least the info will be correct in the factory ones kurt
Old Jun 7, 2007 | 11:43 PM
MadMikeZ28's Avatar
Default RE: manuals
The old Chilton's had much of the factory information inside. The exact same stuff in the helm manuals. The only problem with that very same info in the Being in the Chilton's is it would give you an area to refer to (because its right out of the helm manual) and the reference would not be in the chilton's. The old Chilton's are big. They have the factory info. The new chilton is small and its a haynes in disguise. The ways I identify the difference in the two. Small and says "Chilton" (no "s") on the cover its a haynes. large and says "Chilton's" Its a good manual with factory info.
