Cutting out on top end??
Hey, new to the site. I just bought a 2015 ZL1 with only 6900 Kilometres. The list of mods it has:
-borla long tube headers
-cold air intake
-borla x pipe Offroad racing with cat deletes
-Diablo custom tune to stop o2 sensors for cat deletes and increase fuel pressure
-underdrive pulley for supercharger boost up 30-40% above stock from Lingenfelder
i was passing a car on the highway today in 6th gear around 3500RPM and the car just cut out almost like it was losing fuel, I don’t think it was a misfire because I had no check engine light come on. Tried a few more pulls after and it did it again in 5th gear.
I checked for codes and there is 2 codes stored,
P2097
P2098
-cold air intake
P2097
P2098
The problem is the tuner didn’t come with the vehicle. Previous owner traded it in on a truck and didn’t leave the tuner. This was the info I got from the salesman. I tried getting the previous owners name but the dealership wouldn’t give it to me.if you look at the codes its actually lean on one bank and rich on the other.
Either find a tuner and have them remove present program and go back to OEM program, find another PCM from salvage yard, or visit a GM dealership and have them install OEM program.
Speed must be fast, aka, 3500 RPM in 6th gear, 50% overdrive, has got to be quick.
Hey guys, I've been noticing on my 2021 SS that at high RPMs, especially in 6th gear, the engine seems to dip out a bit on the top end - it's defintly not pulling as hard as it does in lower gears, or even 5th at 5500+ RPM. Anyone else experience this, or is it just me and my tunes?
