Will these tires fit
Im not sure if these tires will fit on my 89 camaro does any one know for sure if they will. I have 8 in eagle alloy rims on. http://cgi.ebay.com/ebaymotors/MICKE...QQcmdZViewItem
thanks for the input i ready need it.
RE: Will these tires fit
probably would rub and on an 8" rim that tire would sit too tall and the rear of the car would sit too high also
To tall? it's a 275/50..........the OD is 26' that is shorter then a 235 60. the sides may rub a little but it won't be to tall. What do you have now? and what would you run up front? If you run that size you would have to run a 225/60 or 215/60 up front .
I have a 225 60 15 on the front right now and a 255 70 15 on the back and thats is 28.1 in tall so i want to go a little shorter but i wanted to know if the other ones will fit or not. They might be too wide but i read some where with the right off set they would fit, i was just wondering what that offset was.
157 a piece that is a lil high
Look on the inside of your rear tier, if you have about 1/2 inch gap then the 275's will fit.275's are only 2 cm wider then the 255's you have now so see no reason for them not to work.
