Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
test
Old May 11, 2007 | 07:57 PM
Default test
Test pix
1953 Henry J, 331" Chrysler marine hemi, real GMC 671 blower @ 23 PSI, Enderle injectors, Cadillac LaSalle 3 speed,Mallory dual coil ignition,5.12:1 rear, 800 HP @ 8000 RPM, forged pistons, Howard aluminun rods, Isky solid roller cam, 9.5 ET @ 165 MPH
Car bent frame & body on 4th run & body wasjunked
[IMG]local://upfiles/1197/7C1F04867DD24AF5A61A223D4E9D1B49.jpg[/IMG]
Old May 11, 2007 | 08:08 PM
74454bb's Avatar
May 2007 ROTM
Default RE: test
Man if that isn't an old school pic I don't know what is.
Old May 11, 2007 | 08:22 PM
Default RE: test
Was shot with a Kodak Brownie. LOL
Old May 11, 2007 | 08:27 PM
74454bb's Avatar
May 2007 ROTM
Default RE: test
Not to call you old, but was that the kind where they stuck their head under the tarp and squeezed a bulb? And I have never seen carbl like those before.
Old May 11, 2007 | 08:58 PM
Default RE: test
Not that old, prolly 1960 vintage,just a small4" cube .Only worked on bright sun. LOL
Those weren't carbs, but barn door fuel injector with two 4"X 5" throttle bodies. Stick your fingers in there and risk getting them crushed by the blower. Fuel pump increased pressure as engine speed went up. A/F ratio was guessed at by looking at color of spark plug tip at end of run, and adjusted by changing the size of the fuel return restrictor.
Old May 11, 2007 | 09:20 PM
74454bb's Avatar
May 2007 ROTM
Default RE: test
I bet that was fun to work on, When you say test , does that mean you have more of these coming? I hope so they are cool.
Old May 11, 2007 | 10:49 PM
Default RE: test
It is too bad the picture doesn't show the paint job. Sprayed with bugandy laquer using too much air pressure. Felt like sandpaper. LOL
Old May 11, 2007 | 11:27 PM
74454bb's Avatar
May 2007 ROTM
Default RE: test
Good ol sand paper finish, Is that a chain spining the blower? Would have been great to look in and see it work....9 seconds, thats about as fast as it got back then.And still verry fast today.
Old May 12, 2007 | 10:22 AM
Default RE: test
The blower was chain driven, timing belts were just coming out. ET was turned on a concrete runway at closed airport near Montgomery, NY. I don't it would run that quick on today's asphalt strips.
RedNickel
Aug 2, 2008 09:55 PM
