Rust Aid
Rust Aid
I ws checking out the wheel wells for the first real time today, two are perfect, one has a few spots of missing paint and some minor surface rust, now the other driver side rear well has a few holes spread out.
Now the other spot where there is rust/holes in just directly below the bumper and license plate.
Is there a safe fix job on those spots, with or without bondo?
The rest of the body is in very good shape overall, it even has the original red paint.
RE: Rust Aid
scotch pads are pretty good about removing surface rust. I have never used them around paint though just chrome mostly
RE: Rust Aid
wier wheel grinder and a sanding pad then buy a gallon of por 15 heres the site http://www.por15store.com/index.html and i will tell u this right now do not DO NOT GET THIS WHERE U DONT WANT IT BECAUSE U WILL NOT BE ABLES TO GET THIS OFF THIS IS LIKE AN APOIE AND TAKES THE MOISTER OUT OF THE AIR TO DRY THER FOR WHEN U OPEN THE CAN U MUST U MUST USE IT NOW
