EuroLights G2 RealHID & EL-S Sealed Beam Conversion Kits experiences?
Has anyone tried this HID kit?
See:
EuroLights G2 RealHID - Conversion Kits
![](http://www.eurolamps.com/eurolamps/realhidinstall2.gif)
Similarly, has anyone tried their sealed bulb conversion kits for older Camaros (i.e. 1995)?
See:
EuroLights EL-S Sealed Beam Conversion Kits
![](http://www.eurolamps.com/eurolamps/4351angle.jpg)
Thanks in advance -- also any Camaro HID install/vendor advice would be great -- any other options which are better? It seems that HID bulbs are only used in low-beams for legal reasons -- is that accurate?
See:
See:
I've installed an HID system on a Cavalier. It was very straight foward and very easy to install. I have a 79 Camaro with the conversion lights and they work amazing. Both of them were easy and direct fitting. DO NOT TOUTCH THE BULB!!! THE HID will flicker when you turn them on, just like floresent lights. So don't be alarmed.
Which brand/vendor did you use for each?
Thanks.
Thanks.
ORIGINAL: shnormo
mrfreez
02-04-2010 11:33 PM
