VS Cars going head to head!
5.0 vs. 79 Z28
Old Jan 5, 2006 | 07:34 PM
imawesome's Avatar
Default RE: 5.0 vs. 79 Z28
no 2.73 are the stock gears
Old Feb 4, 2006 | 12:05 AM
mattvogt's Avatar
Those 5.0's are fast. I have seen them kill stingrays. better watch out.
Old Feb 5, 2006 | 10:06 PM
v8chvyguy's Avatar
You'll thump him off the line but by the end of the quarter he'll blow you away. That 302 will spin up faster and the 2.73's will give him more speed at the end. You will run out of gear and unless your motor can sustain 7 grand you will run out of acceleration to soon. His motor will have power in reserve and yours will be out of breath. Low gears require alot of motor in order to make speed.
Old Feb 10, 2006 | 12:16 PM
Obsol3te's Avatar
Having steeper gears doesn't make you accelerate quicker on the top end.
It DOES however give you a higher top speed.
Old Feb 10, 2006 | 09:07 PM
JD1969's Avatar
ORIGINAL: v8chvyguy
WOW you sir have no clue. The 2.73 will hold him waaaayyy back, the realtivly weak 302 will not have the torque to "pull" such a high gear. The Z/28 in question has a 3.42 gear, thats really a mild gear and you don't even know if his tire is taller than stock or not (which affects the final gear ratio). Even if they were going for a top speed run the Z will still come out on top. Also for those that think a stockish 302 has good top end, obivosly you have never owned one (I have had a few) those motors give up at abot 5000 rpm in stock form so I would hardly say they are top end monsters. The benifit of the 5.0 is that, like the 350, there is a very good after market.
Old Feb 10, 2006 | 11:53 PM
imawesome's Avatar
well i think his nitto NT 555R tires prolly help him alot
Old Feb 12, 2006 | 04:06 AM
v8chvyguy's Avatar
All I know is many moons ago (8 or 9 yrs) I knew a guy with an 87 5.0 GT, stock drivetrain, T5 and mild motor, normally aspirated, beat 2 other stangs, Z28, a vette, and a 72 C10 truck (easy win), all in the same night at the track. He was tunrning consistent 11.7's in the quarter. the last two runs were on seven cylinders, # seven shorted a plug wire causing an intermitent miss once we taped it up, and we did'nt have spares. No, I've never owned one, but, I've had friends that had stangs of that generation and they were pretty formidable. I wached'em beat other cars and get beat by better cars, but, they will walk and talk. During the late 80's I watched alot of SCCA street stock class raceing at the track, at the time the front straight was the quarter mile drag strip, and I noticed that the mustangs would beat the Camaros on the straights almost everytime, but, could'nt out corner or out brake them. Considering the motors and drive trains had to be stock that tells me the mustangs had them beat in the gear department, which is why they could'nt compete in the corners, to much momentum. This may not be the best comparison, but, it's what I based my opinion on. I over exaggerated in my last post, I apologize. The 5.0 may not beat the Z28, but, I think he'll give him a run for his money.
Old Feb 26, 2006 | 06:34 PM
keney4's Avatar
yeah but you can go to any drag strip and watch a 5.0 beat camaros. that does not necessarily mean that those 5.0s are set up like this one they can have alot more dumped into the motor
Old Mar 11, 2006 | 12:21 AM
blkcamaro's Avatar
it might be a good race if the 5.0 got some different gears. They can haul pretty good.
Old Apr 11, 2006 | 09:36 AM
  #20
IBADRIDE's Avatar
i have had a bone stock 91 Z28 5.7 and in louden new hampshire at there drag track i never lost to a stock 5.0 stang, more even race when it came to the newer ones at the time like the 99's. and at that time i was pulling 13.9- 14.0 at around 99mph. and that was when the car had 120,000 on the motor.
Aaron
