350Z
RE: 350Z
ORIGINAL: SpecterGT260
^^^^ nobody rates at the wheel. all ratings, even the grossly erroneous ls1 ratings, were intended to be interpreted as crank. in the same platform, any differences in power can be accredited to intentional marketing ploys.
the older ones were in the 280s, the newer ones rated around 300, that is not at the wheels, or at lease i pray to god it isnt since the things arent that heavy and run 14s....
RE: 350Z
i know bmw doesnt. the 333hp M3 was a crank rating. I also doubt vw does. people speculate from time to time, but i dont think there has ever been a rating from the factory for the wheels. usually because the factories test the motor on an engine dyno during developement, so there is little need for a chassis dyno measurement as well
RE: 350Z
The forum is acting up again. spec is right all engines are rated at the crank VW and BMW are the same way. The LT1 is a great engine and with supporting mods can be a good run for the LS1 [>:]
RE: 350Z
2008 Nissan 350Z Base Hatchback Performance & Efficiency Standard Features
-[/align]3,498 cc 3.5 liters V 6 front engine with 95.5 mm bore, 81.4 mm stroke, 10.6 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder VQ35HR[/align][/align]-[/align]Premium unleaded fuel 91[/align][/align]-[/align]Multi-point injection fuel system[/align][/align]-[/align]20.1 gallon main premium unleaded fuel tank 16.7[/align][/align]-[/align]Power: 228 kW , 306 HP SAE @ 6,800 rpm; 268 ft lb , 363 Nm @ 4,800 rpm[/align][/align]
