Vendor Special Buys Official Sponsors of CamaroForums.com ONLY! If you are interested in becoming an official sponsor, contact us.
Nitto NT555 Performance Tires are Perfect for Muscle Cars
Old Jan 10, 2023 | 12:20 PM
carid's Avatar
Former Sponsor
Default Nitto NT555 Performance Tires are Perfect for Muscle Cars
Engineers at Nitto use decades of experience in the field to recognize and prevent unfavorable tire responses in a range of driving situations and implement computer-modeled designs for reducing road noise and enhancing dynamic contact points while driving. As a result, Nitto experts are able to produce really high-quality tires with prolonged tread life, increased grip on both wet and dry roads, and improved driver satisfaction thanks to tested scientific advancements in creating better polymer tread compounds.
Introducing the ultra-high performance street tire of the newest generation, built with performance drivers in mind. The NT555 G2 will get you off the start line faster, offer stability in the straights, and give you confidence in the bends thanks to its improved traction, handling, and wet-braking characteristics.
The NT555RII tire is a competition drag radial rubber that complies with DOT regulations and is made with more flexibility for weekend drag racers. It’s perfect for the rear wheels of high-horsepower muscle cars. This tire's high-grip compound and semi-racing design work together to maximize traction.
NITTO® - NT555 G2
https://www.carid.com/nitto-tires/nt...-96195603.html
Features:
• Larger Tread Blocks
• Twin Center Ribs
• Large Tapered Blocks
• Circumferential Grooves
• Reinforced Shoulder Tread Blocks
• High stiffness and silica compound
NITTO® - NT555RII
https://www.carid.com/nitto-tires/nt...859080820.html
Features:
• The overall construction has been modified to improve launch performance. The NT555R is designed to achieve a balance between maximum dry performance and occasional street use.
• A semi-radial construction combined with a unique reinforced package helps provide stability at high track speeds.
• The tread compound is formulated to achieve a balance between tread wear and drag strip performance.
You can browse all Nitto tires on our site:
If you have any questions, give our sales team a call at 800.505.3274 (Toll-Free) or 1.609.642.4700 (International).
carid
Vendor Special Buys
Mar 30, 2022 08:10 AM
carid
Vendor Special Buys
Aug 3, 2021 08:06 AM
carid
Vendor Special Buys
Feb 8, 2019 08:17 AM
