Vendor Special Buys Official Sponsors of CamaroForums.com ONLY! If you are interested in becoming an official sponsor, contact us.
Ensure the conversion of harmful gases with iD Select catalytic converter + Promo
Old Apr 28, 2021 | 07:25 AM
carid's Avatar
Former Sponsor
Default Ensure the conversion of harmful gases with iD Select catalytic converter + Promo
The catalytic converter plays a crucial role in your car's exhaust system. If your car has failed its emission test, you might need a replacement catalytic converter. iD Select has got you covered with its wide range of first-rate products made from top-grade materials on modern, high-precision equipment, which allows the brand to maintain the highest standards.
To pass an exhaust emissions test, the converter must have the exact configuration and capacity as specified by the OEM, and the iD Select product meets these requirements. Designed to replace your worn-out or malfunctioning components, they’ll provide the same fit, form, and function. With its corrosion-resistant, stainless steel construction, you can rest assured that it will serve you for years to come.
Shop now and save up to 34% on iD Select Products at CARiD. This offer expires on June 16, 2021. Prices are already reduced.
iD Select® - ECO III Direct Fit Catalytic Converter
https://www.carid.com/id-select/eco-...converter.html
iD Select® - ECO II Universal Fit Catalytic Converter
iD Select® - Standard Exhaust Manifold with Integrated Catalytic Converter
https://www.carid.com/id-select/stan...converter.html
View the full list of iD Select Products: https://www.carid.com/id-select/
carid
Vendor Special Buys
Apr 16, 2021 09:14 AM
carid
Vendor Special Buys
Mar 29, 2021 09:30 AM
carid
Vendor Special Buys
Dec 13, 2019 09:07 AM
carid
Vendor Special Buys
May 8, 2019 08:25 AM
