OBDII scaner
Old Dec 23, 2009 | 04:07 AM
oxigide09's Avatar
Default OBDII scaner
Also keep in mind that for the very first data logging frame or if you are in monitor mode, there is no previous frame, so Obdii.CurrentFrame - 1 is invalid. You may want to handle this situation in your script.
Old Apr 16, 2010 | 09:33 PM
osduck5's Avatar
This is the one I bought last week.
http://shop.advanceautoparts.com/web..._T|GRP2018____
Easy to get the codes but I am still figuring out the readings on the sensors during a drive test. It also lets you reset the codes. Supposedly, it does everything except ABS codes. However, I have AIRBAG light on and there are no codes pulling from the computer for the airbag.
Old Apr 17, 2010 | 03:04 PM
I would love to know how to pull ABS and air bag codes. If you run across anything let us know.
Old Apr 17, 2010 | 08:36 PM
osduck5's Avatar
I know it can't do ABS codes but I am not sure about the Airbag system and how it works with the computer. Does the airbag system even set codes? I don't know. I did, however ask about this code reader and the airbag. The person I was talking to did tell me that this particular scanner would do everything EXCEPT ABS. This is the first one I have ever used and am just getting my feet wet with the electronic diagnosis of a vehicle.
grasshopper645
Jul 22, 2015 07:54 AM
NorthernCrew454
Apr 25, 2011 04:35 PM
Riksterbro
Sep 23, 2010 09:32 AM
BasicConcepts
May 18, 2010 10:37 PM
shrevestang
Jun 21, 2009 11:19 PM
