April ROTM winner - craby
Originally Posted by craby
Thanks go out to everyone. Very nice that t topless lt1's are at the top.:) I hope to have the 12 bolt in before summers end and the 383 in before xmas.
http://i1018.photobucket.com/albums/...s/P1260012.jpg The car is a 93 LT1 hardtop (t topless) with the 4L60 trans. Engine/Drivetrain Modifications: Intake by elliotts port works fully ported enlarged runners 58mm tb opening 58mm bbk throttle body LT1 LE2 heads by elliotts port works manley 2.00/1.56 6000 series valves patriot gold extreme springs (155 lbs seat and 400 lbs open) 205 cc intake port flow about 275/190 CFM bullet racing cam grind #CLT276/281-12HR 223/230 .565/.565 112 separation single roller timing chain with gears aluminum billet oil pump drive housing ARP 134-7103 7/16 rocker studs Trick Flow TFS-21407100 Pushrods, 5/16 x 7.100 comp cam 1305 roller rockers 1.6 7/16 pro magnum tpis performance roller lifters GM performance composition head gaskets part # 12553160 .028 compressed thickness gm performance oil pump NAL-12555884 5.5 qt moroso oil pan 20185 arp oil pan studs 234-1901 arp main bearing studs 134-5601 moroso oil pump pickup 24212 rpc valve covers kooks 1 3/4 x3 headers jethot coated kooks catted y pipe jethot coated corsa cat back with 3 1/2in. double outlets. patc level 3 transmission with the raptor drive and and power gear upgrades patc 5x power raptor lockup 2000 stall torque converter with a torque multiplication rate of 2.5. derale 7 1/2x11 transmission cooler spohn driveline 373 gears Suspension Modifications: koni double adjustable struts koni adjustable shocks spohn panhard bar spohn crossmember mounted torque arm spohn shock tower brace spohn rear lower control arms spohn subframe connectors powerstop slotted & drilled rotors hawks ceramic pads strano braided brake lines Wheels/Tires Modifications: Front 17x8.5 Billet 245x45 Back 17x11 Billet 315x35 Interior/Exterior Modifications: white face gages kenwood kdc-x994 kenwood kfc-c1739ie 6-3/4" 3-way speakers pioneer ts-a1782r 6-3/4" 4-way speakers mtx t-form 93-02 camaro black w/10" sub okole seat covers __________________ For craby |
congrats craby!
congrats!!
thanks guys. appreciate it.
congrats craby
Nice!!!!
1 Attachment(s)
Congrats on the W!! I hope to learn from your example. :)
Perfect shot!!!
