View Poll Results: who ya votin for?
Kandi<3
11.27%
Puck90a
9.86%
nj85z28
4.23%
Craby
11
15.49%
montecarlogrrl
9.86%
DarlingReject
7.04%
whammer3024
23
32.39%
WIspartan1026
2.82%
DarkKnight
7.04%
Voters: 71. You may not vote on this poll
Vote for April ROTM-4th Gen!
its that time ladies and gentlemen. the nominations thread was crazy, now its time to put all of that to work by voting for your favorite 4th gen for April ROTM!
the nominees are(in no particular order, just how i felt like putting them up):
Kandi<3
98 camaro, 3.8L v6
Puck90a
95 Camaro Z28
Craby
93 Z28 A4, LE2 top end
nj85z28
98 Camaro SS #763 LS1 with an A4
montecarlogrrl
2002 Camaro Z28
Darling Reject
98 3.8, lower, modded interior, pacesetter headers, magnaflow muffler with dual pipes
whammer3024
97 Camaro SS 396 LT1, about 430HP to the rear wheels
WIspartan1026
1994 3.4L auto, LS1 SS exhaust, deleted cat, 221k miles
DarkKnight
modified 2000 Camaro SS M6
Kandi<3
98 camaro, 3.8L v6
Puck90a
95 Camaro Z28
Craby
nj85z28
montecarlogrrl
2002 Camaro Z28
Darling Reject
whammer3024
WIspartan1026
DarkKnight
Posting for Craby...
1993 Z28 A4
I have had the Wildcat for a year and a half now and have been making improvements from day one. I plan to install a 373 12 bolt Strange rear-end with Eaton center and reinstall the PATC 4L60 level 3 transmission when i get it back.
Improvements to date are;
new crate short block
Intake by elliotts port works
fully ported
enlarged runners
58mm tb opening
58mm bbk throttle body
30# red top injectors
holley adjustable fuel pressure regulator
LT1 LE2 heads by elliotts port works
manley 2.00/1.56 6000 series valves
patriot gold extreme springs (155 lbs seat and 400 lbs open)
205 cc intake port
flow about 275/190 CFM
bullet cam grind #CLT276/281-12HR
223/230 .565/.565 112 separation
single roller timing chain with gears
96 vented style front cover
vented opti
comp cam roller rocker arms
1.6 7/16 pro magnum
tpis performance roller lifters
5.5 qt moroso oil pan
arp oil pan studs
arp main bearing studs
GM Performance high pressure oil pump
moroso oil pump pickup
rpc valve covers
GM performance composition head gaskets
part .028 compressed thickness
kooks 1 3/4 x3 headers jethot coated
kooks catted y pipe jethot coated
corsa cat back
spohn panhard bar
spohn cross member mounted torque bar
Boyd Cottington Wheels
View my album for more pics
https://camaroforums.com/forum/members/craby-16413-albums-my-baby-146/
1993 Z28 A4
fully ported
enlarged runners
58mm tb opening
205 cc intake port
vented opti
1.6 7/16 pro magnum
arp oil pan studs
rpc valve covers
corsa cat back
spohn panhard bar
Posting for nj85z28
1998 Camaro SLP SS #763 Purchased 12/2009 to replace my 86 Monte Carlo SS.
121k
LS1
A4
Bilstein shocks
Clear Corners
Magnaflow cat-back
Otherwise stock
This is my second fourth gen Camaro. While I have big plans for this car, I need to sell the remaining SS parts from my Monte Carlo in order to make that happen. Right now the current mods are minimal, and the only one done by me is the shocks. So far everything has been original that was replaced. This car was taken care of, but not well maintained. Its not a garage or trailer queen, and is driven as often as possible, weather permitting.
Future mods include Spohn SFC's which are purchased and sitting in the box, a new rear, headers, cam, heads, a high volume oil pump and a full tune.
If I could rebuild the car entirely, I would go with the LS2/T56 out of the GTO.
view more pics at:
https://camaroforums.com/forum/garage...9-nj85z28.html
121k
LS1
A4
Bilstein shocks
Clear Corners
Magnaflow cat-back
Otherwise stock
view more pics at:
posting for ME! lol
first off, here's my album:
https://camaroforums.com/forum/members/whammer3024-8158-albums-whammer3024-1062/
i suck at taking pictures, lol
quick history...
got the car when i was 21 years old...me and a buddy flew down to florida to get it, drove it back. had about 50k on it at that time...5 years later, one new motor and a paintjob later, she sits at around 74k. i truly own my dream car and i wouldnt' sell it for anything
now for the fun stuff...as many of you know i blew my engine up last summer trying to do a cam swap...well i made up for it in a big way with a 396 LT1.
rundown of the engine:
396ci LT1
11.4:1 compression
Bore cylinders 144
Hone w/plates 125
Align hone mains 125
ARP man studs 80
Deck block 125
Internally balance assy w/metal 240
Heavy Metal 7/8” x 1.200 45
Heavy Metal 5/8” x 1.200 32
Clearance block for stroker 80
Install billet main caps, align bore 366
Splayed main caps 220
Grind, tap, deburr block 150
Callies Dragonslayer forged crank 899
Lunati billet 5.85” rods 1499
JE SRP 4.030” forged pistons 559
Top ring 69
Second ring 59
Oil ring 59
JE 52s Pro wrist pins 144
LT1 complete gasket set 237
Hyd roller 234/242 299
Comp R lifters 239
HD timing set 289
Fed Mog Main bearing (coated) 118
Fed Mod Rod bearing (coated) 99
LT1 freeze plugs 10
Blueprinted oil pump 69
More Perf. Engine saver 20
Mardened pushrods 7.150” 119
ARP 12pt. Headbolts 145
Spark plugs 16
Comp Pro Mag 1.6 rockers 279
Custom wire set 129
42# injectors 495
Stage 3 ported LT1 heads 2075
Canton 15244T pan 349
Canton pickup 39
Timing cover upgrade 42
Oil pump drive 58
car makes around 430 horses to the rear wheels...is a blast to drive
some other things done to the car...
car got a brand new paintjob about a year ago thanks to some dog deciding to make it a playground...so she sparkles real nice now!
k&n CAI, BMR subframe connectors, UMI lower control arms with relo brackets, pacesetter longtubes and y pipe mated to SLP 2otl exhaust(best sounding exhaust IMO), been lowered 1.5", ZR1 17"chrome rims, sound system...i'm probably forgetting so much but i'm tired, lol
quick history...
396ci LT1
11.4:1 compression
Bore cylinders 144
Hone w/plates 125
ARP man studs 80
Deck block 125
Top ring 69
Second ring 59
Oil ring 59
Comp R lifters 239
HD timing set 289
LT1 freeze plugs 10
Spark plugs 16
Custom wire set 129
42# injectors 495
Canton pickup 39
Oil pump drive 58
Last edited by whammer3024; Apr 16, 2010 at 08:46 AM. Reason: because i'm an idiot, okay?
