April Voting!! 4th Gens
Old Mar 11, 2008 | 10:41 PM
  #151
SpecterGT260's Avatar
Ninja Administrator
Default RE: April Voting!! 4th Gens
not like it matters too much, u also make it obvious you look down on v6 guys and own a "12 second" near-stock 93 z , for the record, how many of u college guys in here own 2 cars, one being a v8 fbody and the other an 03 sedan?
[/first official time specter bragged about self on forum]
Old Mar 11, 2008 | 10:42 PM
  #152
Ninja Administrator
btw, we have gotten damn close to the level of posts from back when hawk was doing this . U done me proud guys (and girl)
Old Mar 11, 2008 | 10:47 PM
  #153
Saint_Ali's Avatar
12.84 does qualify as a 12 second f-body
Old Mar 11, 2008 | 11:06 PM
  #154
95slvrZ28's Avatar
Sorry Alih, but I have to call BS on that run if you only have the mods listed in your sig.
You have a CAI and true duals (headers aren't even listed), 24 lb/hr injectors are stock size, and the MSD opti can't make too much of a difference over a stock Opti unit. The car came with Bilstien level 1 suspension if it's origionally a Z, and even a drag suspension can't get you a good enough launch with drag tires to pull a 12.8 out of a bolt-on LT1...
Old Mar 11, 2008 | 11:08 PM
  #155
BluBeaSSt's Avatar
Ive got a clean 4th gen [&:]
Can I play?
Old Mar 11, 2008 | 11:11 PM
  #156
BluBeaSSt's Avatar
ORIGINAL: 95slvrZ28
Oh BS you cant, had on 97 Formula, long tubes, cut out, Pulley,CAI, ET streets, LT4 Clutch TUNE (massive amount of HP gain after the Headers) ORY, 12.82 @ 105
Old Mar 11, 2008 | 11:12 PM
  #157
Ninja Administrator
i wasnt going to call BS, i was just going to say it couldnt happen [&:]
Old Mar 11, 2008 | 11:16 PM
  #158
95slvrZ28's Avatar
ORIGINAL: BluBeaSSt
ORIGINAL: 95slvrZ28
?? You listed long tubes, a cut out and a tune, all things that will get you power, and then you listed ET Streets, which will get you off the line faster than street tires. On a 3inch true dual (no headers) and CAI car you cannot pull a 12 sec pass...
Old Mar 11, 2008 | 11:24 PM
  #159
Saint_Ali's Avatar
ok dude since you want to get technical
i have off road long tube hooker ceramic coated headers with a 3inch flowtech x pipe with cut outs and dual dynomax ultra flow race mufflers, drag radials, completely gutted interior, k&n cold air intake, i have the after market bilstein shocks not the stock ones, 24 lb fuel injectors, i have no cats and have removed the air conditioning unit, as well as having a complete MSD ignition with a timing advance
is that better jack *** ?
Old Mar 11, 2008 | 11:27 PM
  #160
Ninja Administrator
actually yes it is
he wasnt being a jack *** (or jackass? hmmmm [:-]), he said "with the mods you listed" which is a true statement.
