ZEX TPS switch
RE: ZEX TPS switch
its universal. it just reads the voltage coming from your TPS. it isnt a zex TPS switch, its an electronic WOT switch. you program it to activate and close the circuit at a certain voltage.
RE: ZEX TPS switch
Thanks for clearing that up you learn someting new every day. I didnt know if there was a second wire or what needed to be done. Thanks for your help. Do you know how it is marked.
RE: ZEX TPS switch
when i used ZEX i had the NMU all-in-one box. it was the white wire there.
check www.zex.com they may have a pdf with instructions. otherwise email them. i had alot of contact with them when I was using my kit, they are pretty helpful.
