Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Twin Turbo 3.8L
Old Apr 21, 2008 | 10:28 PM
96WhiteLightnin's Avatar
Default Twin Turbo 3.8L
So i'm gonna try and turbo my 96 rs but i'm not sure what all i need. i can get the turbo's off of two volvos in my autoshop class and i'm pretty sure i'll have to have the piping custom made, what else do i need? forged pistons? injectors?
Old Apr 22, 2008 | 06:17 AM
02StanGT's Avatar
Default RE: Twin Turbo 3.8L
You will need:turbo or turbos, oil line for turbo(s), turbo manifolds and downpipe, intercooler, all the intake piping, wastegate, blow off valve, bigger injectors, bigger fuel pump, some body work to fit the intercooler, tuning, new plugs, forged rotating assembly, upgraded drivetrain (if you plan on putting tons of boost to it), adjustable fuel pressure regulator would be nice to have, and I'm sure I'm missing some stuff. To make the most of it, a cam, P&P heads, and upgraded valvetrain.
Old Apr 22, 2008 | 12:59 PM
CamaroKid16's Avatar
might as well pull the engine, rebuild, and then custom fab everything while putting it back in. lol good luck
Old Apr 23, 2008 | 12:21 AM
Thanks Stang and those were my thoughts exactly camaro kid, the engine has 130k miles on it so i was thinking a rebuild might be required
Old Apr 24, 2008 | 10:05 PM
camaro_burns_all's Avatar
VIP member
1 -Turbo
2 - Manifold
3 - Intercooler
4 - Charge Piping
5 - Couplers and Clamps
6 - Air Filter
7 - Wastegate
8 - Blow Off Valve
9 - Oil Line Kit w/ Fittings
10 - Tapped Oil Pan
11 - Injectors – Higher Flow
12 - Downpipe w/ Flexpipe and High Flow Cat
13 - O2 bung and plug
14 - Dumptube
15 - Vacuum Lines w/ Vacuum T Fittings
16 - Gauges
17 - Gauge Pod
18 - Chipped ECU w/ engine Management w/Tune
19 - Synthetic Oil, Higher Octane Fuel
20 - Spark plugs (one step colder)
KEEP IN MIND these are mostly for 4 cylinder cars. So plus or minus somethings in the list, just give you an idea
21 - Miscellaneous Stuff
Old Apr 24, 2008 | 10:10 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
and your going to need a **** load of money.....
Old Apr 25, 2008 | 12:38 AM
yeah.. which is why this will probably never end up happeneing. i can dream though, can't i?
Old Apr 25, 2008 | 02:25 PM
VIP member
how much do you think you need? Im thinking no more than 5k?
Old Apr 26, 2008 | 03:15 PM
FFF sold an entire custom kit for my car for 3k
Old May 1, 2008 | 02:35 AM
6v49der's Avatar
If you wanna find one of those kits go to FTV6.com, they post pretty regularly over there, and Ive seen some of those kits used floatin around, still pricy though. I wanna say Tiago is one of the owners, but Im not sure, I know he is involved with the long tubes, but not sure about the turbo stuff.
