Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
turbo v6
Old Dec 17, 2007 | 10:10 PM
jj71787's Avatar
Default RE: turbo v6
any websites that sell turbos for 1998 3800 series
Old Dec 17, 2007 | 10:48 PM
02StanGT's Avatar
Did you even read the thread? The second post made, was by me. It said look up Force Fed Fabrications. They make kits for the 3800.
Old Dec 17, 2007 | 11:30 PM
jj71787's Avatar
i looked at it but i dont see where you buy them i just see his projects
Old Dec 17, 2007 | 11:35 PM
02StanGT's Avatar
Email him. Guys name is Tiago.
Old Dec 17, 2007 | 11:37 PM
jj71787's Avatar
ok thanks
Old Dec 19, 2007 | 07:11 PM
cbr600rx7's Avatar
Try contacting STS as well. It shouldn’t be hard to use one of there rear mounted LS1 kits on the V6 since it’s a rear mounted turbo you could probably get away with just moding some of the piping. They don’t offer a v6 kit for the F-body but if you contact them im sure they can work something out. Probably run you around 4 grand and you can have it installed pretty damn cheap for a turbo. They may even work with you on fabricating a new v6 kit and cut you a little deal. I know they have done it in the past on a few vehicles they used as test cars.
Old Dec 22, 2007 | 12:31 PM
jj71787's Avatar
Sts said they can custom make 12 for me rear end buy I don't get how the rear end works shouldn't the turbo be on the engine
Old Dec 27, 2007 | 02:34 PM
cbr600rx7's Avatar
It is a remote mounted turbo and no a turbo can be just about any where. having a turbo in the engine bay puts a lot of weight up front and creates a lot of under the hood temp. Its also hard for F bodys due to the space we have to work with. Basic none ICkits on LS1's have pulled mid 400s at 6 to 7 psi tuned. IC kits at 7 psi and up have pulled low 500s at the ground not to bad. Also the turbo has almost no lag to it. And the turbokicks in hard and fast great for A4s. It is the best bang for your buck next to maybe a wet shot. I know sts will stand behind there kits and i am sure with a little tuning that V6 could pull LS1 times.
96V6Camaro
Oct 11, 2021 09:41 PM
Sixty7 Camaro
Apr 11, 2009 12:54 PM
