Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
turbo LT1
Old 11-28-2007, 05:44 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
Default RE: turbo LT1
question is man why would you go turbo when you can get the same results from a good head and cam job...
Old 11-28-2007, 07:55 PM
1990CamaroRS's Avatar
Fancy Sparkle
ORIGINAL: BigNic
two words, gas mileage. he still wants it to be streetable for a dd
Old 12-01-2007, 09:14 PM
buckfever's Avatar
you still need low compression for a supercharger..same as a turbo... nitrous is actually not that bad for an engine if its set up right... just make sure you get a wet system and do it right and nitrous will be fine.
Old 12-01-2007, 09:50 PM
th3po1son's Avatar
I've always been fascinated with turbos... I'd get a rear mounted one if I had the money.
Old 12-07-2007, 08:35 PM
SpecterGT260's Avatar
Ninja Administrator
h8ter, why would the SC be better than a turbo on his high compression engine? also, many of the honda motors are high compression too. vtec isnt a motor, its just something many honda motors have.
Old 12-08-2007, 12:33 PM
rockin85's Avatar
the big 4 second drag racing motors have 17:1 compression and run 40 or more psi of boost on their superchargers.
Old 12-08-2007, 02:50 PM
red star's Avatar
So a turbo is more work then what it is really worth? That good to know. for a DD car what would heads(like 195CC) and a LT4 manifold do to me gas wise and power wise?
Old 12-08-2007, 03:51 PM
Ninja Administrator
ORIGINAL: rockin85
they also run nitromethane for fuel which has a stellar octane rating. they also are dieseling by the 1/8th mark and you cannot shut the car off without cutting fuel, the engine will continue to fire without spark, the plugs fry every run, the rings last a day. All of this because the car runs under very stressful conditions. This is not a valid comparison. for our purposes high octane motors which will run on gasoline should not be boosted. you must lower compression before you plan to run serious boost.
Old 12-08-2007, 04:47 PM
rockin85's Avatar
o sorry im not a smart person. between us im really dumb.
  #20
Old 12-08-2007, 05:07 PM
Ninja Administrator
must be, because "between us" would be PM and not on the thread!
jk
Quick Reply: turbo LT1
