Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
turbo 3.8
Old May 31, 2008 | 01:45 AM
stroker383's Avatar
Default turbo 3.8
so i've been thinking on how i'm going to do this b/c their are so many options i've decided that if this car is going to look like it's slow the engine bay might as well too... i'm going to use slp headers and pipeing to behind the tranny do my y pipe and place the turbo there i can hide the oil lines and such and pipe the charged air to the stock airbox and from there run a pipe to the throttlebody inside the airbox not to give anything away i understand this will be a good bit of work also my plan for the bov is silence it so that won't give it away... also i bought a 1 litre race tank that i'll use to hold the methanol... for methanol injection if u do turbos methanol injection is 1000% better than nitrous and it's a bit cheaper.. i'm wanting to do a single exhaust to further the appearance of a stock v6 anyone know a good single exit exhaust kit for cheap???
Old May 31, 2008 | 06:32 AM
SpecterGT260's Avatar
Ninja Administrator
Default RE: turbo 3.8
its possible, those STS turbo systems run on a similar design without the concealment. be prepared to spend a butt load on fab tho
Old Jun 1, 2008 | 11:33 AM
98RCMARO's Avatar
Fab work for the STS system?
I was pretty sure those just bolted where your exhaust hangs, maybe some work with the extra piping required to the engine?
96V6Camaro
Oct 11, 2021 09:41 PM
Sixty7 Camaro
Apr 11, 2009 12:54 PM
