Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
TURBO
Old Mar 6, 2007 | 03:18 AM
bumpnbrd2005's Avatar
Default TURBO
Why do some Turbos have a split inlet? IE http://cgi.ebay.com/ebaymotors/T70-T...88760120QQrdZ1
Old Mar 6, 2007 | 01:57 PM
shnormo's Avatar
Default RE: TURBO
It's just like a carb with a spread bore or a split bore or an open bore.
Old Mar 6, 2007 | 02:20 PM
Default RE: TURBO
So do you see any problems using this in a rear mount turbo set-up? Thanks
Dan
Old Mar 6, 2007 | 07:48 PM
shnormo's Avatar
Default RE: TURBO
Rear mount turbos lose the velocity of the exhaust. It can't take advantage of the exhaust pulses to spool the turbo up faster. The intake is so far away, when it gets to the throttle body there is boost but no velocity. So I don't personally recomend them.
Old Mar 6, 2007 | 11:47 PM
Default RE: TURBO
Thanks Norm, you seem to know what your talking about. What is the difference between Boost and Velocity? Thanks
Dan
96V6Camaro
Oct 11, 2021 09:41 PM
Sixty7 Camaro
Apr 11, 2009 12:54 PM
