Tuning with Nitrous
I was wondering how to tune my set up with Nitrous. If I got a 150 hp Shot of nitrous, how would you control the timeing. I don't want to be running retarted the whole time (hahaha I know it sounds funny). If I have a small base circle power cam, would that have to be changed for a "nitrous" grind? I want a wet system set up. What's the set up for hooking up the fuel side of the nitrous?
Nitrous Express and NOS have the under carb nitrous plate. Yes it comes with the hardware. It sates that the timing should be retarted 1 degree for every 10 hp. But if I adjust the timing with the distributor, then my overall timing would be off. How would I change the timing ONLY when the nitrous is applied? I was wondering what ignition box would be able to retard timing only when nitrous is applied.
Norm, A friend of mine runs three stages on a 588 sharoff engine If you hadnt figured it out yet I can ask him for ya. He has a 82 z it is nearly in the 7 second range 170 mph stock bodied car.
ORIGINAL: shnormo
Norm, Do what Z28 Pete said and get a kit designed for Your car. daZ28 is on the money with all of His answers. Understand that NOS is an additional air ( oxygen ) supply and must be compensated with the proper amount of fuel to keep up with that additional O2. Doing that is the key to not hurting parts.
Norm, as z28 stated, there are companies that make controllers for this application. You are absolutely correct to not want to run your timing retarded the entire time in preparation for the nitrous shot. Reality is, you aren't going to need that timing taken out of it until you push the button. Just research a few companies, I know MSD does it so I am sure there are a few others.
