Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Rear Mount??
Old Jun 17, 2009 | 10:56 PM
1990CamaroRS's Avatar
Fancy Sparkle
Default Rear Mount??
does any company make rear mount turbos for 3rd gens???? i can't find jack crap. not even from STS (who specialize in rear mount turbos).
Old Jun 17, 2009 | 11:02 PM
GMDCAMARO's Avatar
I was going to say, Try STS. I guess that would be a no.
Old Jun 17, 2009 | 11:42 PM
Fancy Sparkle
guess i'm gonna have to fab up my own then
Old Jun 18, 2009 | 03:07 PM
cbr600rx7's Avatar
You could take a used STS kit and make it work. Might take a few small changes but it would be a little less pain in the *** then starting from nothing. Plus used STS kits are cheap and come with most of what you will need.
Old Oct 2, 2009 | 06:48 PM
LHill00Z28's Avatar
You can always get the universal components from STS (turbo, piping, clamps, etc) & fabricate it up.. You will have to do a little homework to make sure all of your piping is the ideal diameter, etc & that you have good mounting points & clearances..
Old Oct 28, 2009 | 12:10 PM
LETSROC's Avatar
www.hawksthirdgenparts.com Go 2 this web site he works on 82-02 camaro they can help you out I saw 1 that he did it was sweet
Old Oct 28, 2009 | 05:43 PM
1967rs540's Avatar
stay away from rear mount turbos.. i seen them all the time on my dyno and the numbers they put down is pathetic.. not worth the money. save the heartache and just do a proper front mount setup.
Old Oct 31, 2009 | 10:04 AM
crug75hid's Avatar
yes, Rear side Turbo charges may not worthy to give full services as they can not compensate the heat properly than the front mounted.
Old Nov 9, 2009 | 10:09 PM
cbr600rx7's Avatar
The above is just not true. There are tons of guys out there running good numbers with rear mounted set ups. If heat becomes a issue you can alwase run Meth, Alky or hey add a good Front mount intercooler to keep the temps down.
No a single STS turbo kit is probaly not going to produce the same power as a Twin APS kit but your also talking about twice the price and a much harder install.
For a budget FI set up on a LS1 car you can make 450 plus horses on a STS kit for about 4 grand brand new. The APS kit may make a little over 500 but its going to cost about 7 grand and the installation is about three times the work.
Plus once you start going past the 450 mark you might as well say good by to your A4 and 10 bolt and be ready to drop some big money on your drive line somthing that not every F-body guy wants to do.
Also there are 700,800 and 900 Horse power guys out there running rear mount set ups so they can make the power. They are not worth less and on a budget FI build they have there place.
Old Feb 18, 2010 | 07:56 PM
Sinclairaity's Avatar
I called STS and i'm putting a ls1 in my third gen 1990 RS btw lol good choice man
but i asked if the piping would be close to a 4th gen they said it would but it's just cheaper to go with a universal kit and it's more custom and would fit better. So don't just not do a rear mount cuz there's not a bolt on kit. Go ahead and do it man! much better than a front mount. turbo is 500 degress cooler than it would be in the front
