Procharged 383
Procharged 383
I own a 1995 procharged (8psi) lt1 i was looking at
Ai Pro-Series Forged 383cid LT1 Rotating Assembly Package:
Compstar Forged 4340 3.75" Stroke Crankshaft Compstar Forged 4340 H-Beam Rods Mahle Pro-Series Forged Pistons Mahle Plasma-Moly 043"/.043"/3mm Ring Package Mahle Steel Pins & Wire LocksMain and Rod Bearings Included Internally Pre-Balanced by Callies/CompStar!
can i run this package on my stock heads.
RE: Procharged 383
keep your posts in one section...slvr will get mad at you if you keep posting the same stuff in different sections. and as said in a different section, YES YOU CAN RUN YOUR STOCK HEADS WITH THIS. you won't get as much HP as you should if you had ported heads
RE: Procharged 383
As said above the set up looks good but you are not going to get no where near what you could out of it on the stock heads and cam. Since you are running forced induction you need to figure out how much boost you want to run and match a good comp ratio to it. And he is right about posting in more then one section slvr is not the one you have to worry about its the NINJA ADMIN running around. You dont want him to kill you with his NINJA STAR now do you [X(]
RE: Procharged 383
Lol i dont see what the big deal is about putting multiplepost thats the whole point of the website. Who cares if u put it in more than 1 seriously. How old are you cause you seem pretty imature about the whole thing, im simply asking a question and all you ever have to say is negative feed back grow up kid..
But Ls1 ive already talked to some one im going to get heads and custom cam package 223/231 .565/.583 112 LSA. along with the compstar 383ci assembley package he said i should be making 500-550 RWHP with 58mm throttle body 1 3/4 lts and proper tuning will need to be done. The only thing im worried bout now is that i dont think my rearends going to be able to handle this are at least not for very long what u think what are the stock rear ends rated at horsepower and torque wise thx....
