Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
nitrous questions
Old Jun 29, 2006 | 04:56 AM
fatass91's Avatar
Default nitrous questions
do i need to beef up my engine. such as internals. pistons and such. or would it be safe to put nitrous on a lightly modded car. if it is safe what shot and brand should i get for my Lt1? I appreciate the help. thanks guys
Old Jun 29, 2006 | 07:09 AM
brock417's Avatar
Default RE: nitrous questions
ive asked that same question and everyone has told me that no i dont have to do anything... but to make sure to change the spark plugs and wires...they also so to go with the "wet" systems because with the dry systems you have the chance that the car will run lean.
Old Jun 29, 2006 | 02:40 PM
It depends how much nitrous you are going to use. Without beefing up the internals, and the egine in good mechanical shape, I would stay below 150 shot. Make sure everything is installed correctly according to instructions, and yes make sure the ignition & injection are in perfect condition. I would also install plugs one or two ranges colder to help avoid detonation.
Old Jun 30, 2006 | 12:38 AM
fatass91's Avatar
guys i really appreciate it
Old Jul 7, 2006 | 01:06 PM
NomadicZ28's Avatar
Pete is exactly right, watch how much nitrous you use. A friend of mine has a 96 T/A and it had the Lt1 in it and he ran nitrous through it and melted down the engine, so he rebuilt the engine to a 383 stroker and is running 100 shot nitrous with no problem. So just be carefeull how much you use.
Damon
Nautical
Oct 2, 2009 02:22 PM
bunarski
Aug 25, 2009 05:33 PM
likearock91288
Aug 13, 2007 09:18 PM
traXion
Jun 16, 2007 11:38 PM
microkid
May 7, 2007 05:21 PM
