Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Nitrous for a buck fifty
Old Feb 20, 2011 | 08:05 PM
MelloYello's Avatar
Default Nitrous for a buck fifty
a dudes got a nitrous kit he'll sell me for $150... he bought a camaro and the dude gave him two systems with it.
i know nothing about NO2.... what all is necessary to properly set up a NO2 setup? for a Tuned port FI engine
Old Feb 21, 2011 | 12:19 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Depends, is it a dry or wet kit?
Old Feb 21, 2011 | 10:13 AM
H2C's Avatar
H2C
or direct port? IS IT DIRECT PORT drools
Old Feb 21, 2011 | 11:31 AM
MelloYello's Avatar
I completely lied. he wants 250...
idk wat it is but its installed on his LT1 camaro right now
Old Feb 21, 2011 | 12:11 PM
H2C's Avatar
H2C
Mmmmmm direct port, if it is that or wet id get it, but 250 seems a little high
Old Feb 22, 2011 | 04:09 PM
MelloYello's Avatar
i know nothing about NO2.. anybody want to fill me in? i know the theory of how it works, but i dont know anything about the systems or vocabulary
Old Feb 22, 2011 | 04:36 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Dry: Injecting Just nitrous into your intake via nozzle
Wet: Injecting Nitrous/Fuel into your intake via nozzle
Direct port: Basically a wet setup but has a nozzle for each cylinder.
Old Feb 22, 2011 | 09:19 PM
There are books writen on the subject. N2O if not used right will destroy a motor in minutes. You do not want a used system because you do not understand if everything is there. IMO very few kits come with everything you need to protect your motor. Wet kits can be a lot of work when done right. Your going to need a complete fuel system. You do not want to piggy back off a stock fuel pump. Dry system require more know how. N2O is oxygen, Too much Oxygen and not enough fuel and you will melt your piston. N2O should only be used on motor that are in really good condition with upgraded head gaskets. You should also upgrade the pistons and ring but that is not a must as long as you do not go nuts on the shot size.
You did read the stick How Nitrous work?
Old Feb 23, 2011 | 07:31 PM
MelloYello's Avatar
Negative. now that u mention it i shall
Bankos66
Nov 5, 2010 03:20 PM
chevcamdan
Jun 3, 2007 07:12 PM
American_psyco
Dec 31, 2005 07:23 PM
