More Turbo Q's
The intake is the weakest link. The PCM will have to be flashed to retard your timing and your stock injectors can handel 5 lbs of boost with out any other power adders. You'll also have to run 92 octane all the time. I would also run a water injection system.
Sixty7 Camaro
Apr 11, 2009 12:54 PM
