Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
How to change the boost.
Old 12-28-2007 | 06:10 PM
luvmysccamaro's Avatar
Default How to change the boost.
i am running at about 3 psi and i think i should be running a little bit higher. is there a ways how i can increase the boost? P.S. I am not sure if i have and mods in the engine but im pretty sure.
Old 12-28-2007 | 06:27 PM
Default RE: How to change the boost.
OK so you need a smaller pulley to make it spin faster. What size should i get and what is the most psi my engine could handle?
Old 12-28-2007 | 06:31 PM
cbr600rx7's Avatar
First off we need to know what kind of SC you are running and more info about your set up. You can up the boost by changing out the pully. This will make the Supercharger spin faster and produce more boost. But we need more info on your set up. Depending on the size of your conpressior and your fuel set up will matter on how much boost you can run safe. 3 PSI on a LT1 is probaly producing around 70 to 80 horse power give or take.
Old 12-28-2007 | 06:48 PM
im sorry, but i dont know a lot about this car becuase we bought it as is with all the mods. the supercharger turns out to be a paxton and is has a msd ignition and boost retard. i went to their website and they say 11 psi. is the max for a stock engine. but the thing is, i couldnt find a s/c for a camaro???
Old 12-28-2007 | 06:54 PM
cbr600rx7's Avatar
You need to look on the SC for a part # and look it up on paxtons web site. I would take it to a good shop that has a dyno and invest in a dyno tune this will add a good kick to the SC and make it safer. This will also tell you how your engine is running and give you some idea about how much boost is safe. I dont recomend going past 5 psi with out tuning and fuel managment and fuel upgrades.
Old 12-28-2007 | 06:57 PM
cbr600rx7's Avatar
It is veary inportant for you to find out what mods you have i recomend taking it to a good (F-BODY SHOP).
critt86
02-21-2010 02:30 PM
LHill00Z28
10-03-2009 12:36 AM
irishman12
04-07-2009 04:24 PM
luvmysccamaro
11-22-2007 06:39 PM
luvmysccamaro
11-22-2007 01:32 PM
Quick Reply: How to change the boost.
